I need some info on the transmission. I read that u can mate the 3rz to. The 22r trans by usein the 3rz bell housing is this correct?? What year 22r trans do I need the use and what clutch setup do I need. Any help should be most appreciated.
Yup, you just need the 2RZ/3RZ bellhousing and any W-series transmission. I helped a friend put a 2RZ in his 85 4x4 and I believe we just used the 2RZ clutch as well
Also, do you already have a 3RZ? If not I would look into a 2RZ, slightly less power from the get go, but can handle boost much better if you decide to go that route.
my stock 2rz has some balls man, it will let the tires loose with my garbage auto trans lol ! my 22r stock had like half the power lmao
