So I found a pair I am wanting to buy they will fit for sure right? thanks for always answering my questions guys!
Lug pattern is the same but... Center bore will be your problem. You can have them bored out (67.06mm) or just use spacers. Good luck!
yes they WILL fit. you will need a minimal 1/4" spacer or "shim" you can find them at any parts store (auto zone kragen etc....) Shot with X400,D580Z,C460Z at 2009-06-21
the tail lights were found on ebay but the unfortunate thing was the top clear section of the lenses fogged up to a milky haze..... not sure if the process has anything to do with it but we ordered a set of full clears and they look like new to date. by the way, this truck belongs to MacRib just to make it clear
Yah I was thinking bout putting my stock Z rims on as well since they just sit in my garage, I dont think with the way my notch and bridge is built that they will fit in the rear, I guess thats why they make spacers huh.
I got these wheels on ebay about 5 years ago....they were on a 350z, I bought this $150 truck a week ago....so naturally I had to see if they fit.... The truck had a 1/4" spacer on the front which i dont like, but I left it on since im not driving it any time soon.
I cant remember...lol I know its an ADR M-Sport or something like that, they are 18x9.5 and i think 18x8.5 in the front. Tires I will have to check but I thought they were 265/45's. I lowered the truck by putting a 1000lb boulder in the back, and cutting the torsion bars half way through with the plasma cutter. Nothing but the best for this beater!
What's up guys! The drop on my truck, I want to say, is a 6/6. The front was lowered using drop spindles, TRD sway bars, and then adjusted them to tuck the tires. The rear has 3" blocks and drop leafs and the frame was nothched by Beefed Taco. Eventually, the plan is pick up some drop A arms and readjust to torsions to firm up the ride. Thanks for the kind words, I really like the way the truck has come along.
heres my truck with nissan maxima wheels, same center bore as 350 z wheels. Just run a 1/4 inch spacers you'll be fine
