3.0 V6 short ram intake
Discussion in 'Engine/Drivetrain' started by 93V6yota, Apr 10, 2009.
  1. 93V6yota
    93V6yota Member
    memphis tn
    93 xcab black with 3.0 V6
    how do i put a short ram intake on my 3.0 V6?there is alot of **** on the stock intake and was wondering if i could reroute it or what i needa do
  2. IronNam
    I have no clue what you just meant.
    best you can do for the intake of the V6 is to delete the resonator, run an open filter if you wish, isolate it all from the heat, and then duct cold fresh air to it.
  3. elijah
    elijah Newbie
    I have to agree with you, I also can't seem to understand what 93v6 is trying to say. Anyway, I just find your post such an interesting tip and I think my cousin could follow that because he is planning to hook up a ram air intake this weekend. Thanks for sharing it.
  4. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    If you guys have ever seen a 3.slow intake you'd understand. Everything about that abortion of a pile of scrap metal engine is overcomplicated and extremely over engineered to the point of it being an unruly whore to work on.
    I'll snap a pic of one tomorro... err today. :lol:
  5. White Trash
    Eastern WA
    As promised.
  6. jetas
    ditch the short ram idea along with the 3VZE and swap to a 22RE... Youl thank yourself later....
  7. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    ill see your 22re swap, and raise you a 5vze suggestion :D
    ...... not to mention its also a closer "bolt in" swap for the 3.0 engine bays and trannies.
    as for a real suggestion to his question......... e-bay my friend. you will find a few inexpensive 3vz intake kits you can install. everything should be straightforward on installation. not much has to change except for replacing the stock section of tubing from the throttle body out. everything else should plug back in where its supposed to.
