2wd 3.0 swap to 22RE
Discussion in 'Engine/Drivetrain' started by Sean holm, Dec 10, 2019.
  1. Sean holm
    Sean holm Newbie
    Hi i have a 93 ext cab 2wd. 3.0v6 5speed. Im wanting to swap it for a donor 22re. I have the brain and wire harness. Am i going to need the adapter and or what else am i going to need? Thanks in advance (i wont be able to check messages till after work)
  2. jetas
    Everything ive read says that its simpler to swap in a 3.4 5VZE than it is to swap in a 22R
  3. Sean holm
    Sean holm Newbie
    Yea thats what ive been told also, but i have a 22re donor motor reality available. If i had 3.4 motor i would go that route.
  4. jetas
    You're going to have to remove the mounts for the 3.0 from the frame and make some for the 22r or get some from a donor. Not the part that mounts to the block but the ones on the actual frame
  5. BatryOpratedBoy
    BatryOpratedBoy Enthusiast
    Fresno. =(
    Brave Little Toaster (Diana) and Salsa Verde (Traction Control)
    Sell the donor, get a 3.4, save time and effort on the swap?
    I'm sure it's apples to apples as far as overall cost, either you're paying for more motor, or paying for Fab work.
    jetas likes this.
  6. Alan Willis
    Alan Willis Newbie
    Charleston, SC
    1990 2wd SR5 Xtra cab 5 speed
    What’s wrong with your 3.0?
  7. jetas
    Its a 3.0 thats the problem
  8. Alan Willis
    Alan Willis Newbie
    Charleston, SC
    Mine seems peppy enough... I’m fixing Toyota’s mistakes and seeing how it goes; figure $2,000 into what I have vs $2,000 for more headaches?
    Right now I’m topping out at around 105 with just a timing adjustment and getting rid of some of the emissions crap. Next will be getting rid of the EGR, changing the intake, and slapping in a set of Doug Thorley headers to get rid of the crossover pipe and see what happens
  9. jetas
    Some of us have been tainted by the engine lol
  10. Alan Willis
    Alan Willis Newbie
    Charleston, SC
    Lol; I’ve heard the horror stories.head gaskets don’t last, no hp,gas guzzlers...
    Honestly I was going to do an engine swap as well, but this one pulls strong, so I figure I’ll at least give it a chance
  11. sirdeuce
    sirdeuce Newbie
    The 3.0 isn't a bad engine, just wasn't executed properly. I've found rebuilding the thing works out quite well. make sure you get a shop that knows what they're doing as the block, heads and lower manifold will need to be cut. Once it's done you'll be surprised at the output and longevity.
