282 comp cam?
Discussion in 'Engine/Drivetrain' started by Playinwithtoys, Apr 17, 2016.
  1. Playinwithtoys
    Playinwithtoys Member
    Guam
    91 pickup
    Is this cam any good for a stock RE ? someone in my location is selling a 282 comp cam for $50 and it beats buying a Lc cam for 200$ . I was just wondering if anyone had any feed back on these cams or any info on the peaks and when it falls off or anything in that matter. Thanks if anyone cam help
  2. Litneon
    Cocoa, FL
    94 xtra cab
    It's a decent cam profile. But does it come with the rocker arms? It's already been broken in with a set of followers, if you don't reuse them you run the risk of destroying the cam and your current rockers. Saving a few bucks now can cost a lot down the road.
    Just a thought.
  3. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    looks like a good cam. u'll probably want a bigger one in a little bit. more power is addicting. i've gone through about 4 cams, from Delta, Crower, to LCE. i've been using the same rockers. just make sure to lube up properly and "burnish" the cam to the rockers. make sure to roll the engine over to make sure no valves or anything stick or hit. (a small tip just in case u never installed cam before). when is all good, start engine and hold at 1800 rpm to mate cam to rockers. DONT FORGET ADJUST THE VALVES PRIOR TO STARTING!!!!!!
  4. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    It usually voids warranty if you don't use new or resurfaced rockers with a new cam, but since it's not a new cam that doesn't matter.
    Bad things can happen if you dont, but even with new stuff it still isnt a guarantee.
  5. Playinwithtoys
    Guam
    91 pickup
    Oh yea i know the whole low down on install and matching the rockers to the cam and all i just never tried a comp cam. I mean i want a 292 or something bigger but its a efi i mean my 310outlaw on my carby does fantastic but idk about efi never tried it .will the computer freak out on the cam or what idk never really tampered eith a efi
  6. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    computer will def freak out. i ran a 292 -with A LOT of tweeks. still couldnt get it to really idle right. alot of duration for stock ecu without making the necessary mods. if u gonna go that big, best to get adjustable cam gear
    try it nai
    if u dont like, just sell it and get another one :waytogo:
  7. Playinwithtoys
    Guam
    91 pickup
    Hahaa aye sa i got someone here from the islands . Thanks chelu i just didnt wanna try it out n the computer starts acting up but yea i will try tweaking a few things here and there . Esta thanks
  8. Playinwithtoys
    Guam
    91 pickup
    Someone help please , the stupido guy that said it was a 282 comp cam is no where to be found . Fckn ran up a coconut tree and lived there fckn assholes . I did research and searched it up by the num on the cam and its a damn 280 comp cam. Im fine with it but thats fckd up false advertisement these people nowadays. But the help i need is the cam i got is totally worth 50$ bones the only thing is , i have dual lc springs and all that good stuff but dont want to go through the hassle of buying a new head gasket but idk someone tell me otherwise and put it on. If i run the stock springs will i get a good mid to high range rpm like a savage or will it feel like im loosing cam around 3k or higher ?
