22re spewing coolant
Discussion in 'Engine/Drivetrain' started by CruzadeR, Mar 3, 2012.
  1. CruzadeR
    CruzadeR Newbie
    Georgia
    94 xcab 2wd
    Hey people my 94 yota today started to spew coolant from somewhere around the ac compressor truck runs fine but over heats after about a mile. I checked the oil an does not have water in it. I'm afraid the block might of cracked. I don't know a lot about 22re's so i that's why i asked. I cant see where the coolant is spewing from it does not seem the be the water pump an or gasket, any advice offered would be great thanks.
  2. Ian Nexus
    Ian Nexus Member
    Torrance CA
    93 xcab 22RE 2WDAuto
  3. CruzadeR
    CruzadeR Newbie
    Georgia
    94 xcab 2wd
    Good call you where dead on. Thanks you did not lie when u said it was well hidden!!!!
  4. Ian Nexus
    Ian Nexus Member
    Torrance CA
    It was the only hose I hadn't replaced!, I found it by looking at an assembly diagram in the manual - I never knew it actually existed till it split.
