22re motor swap question OILPAN
Discussion in 'Engine/Drivetrain' started by _Keith_, May 14, 2012.
  1. _Keith_
    _Keith_ Newbie
    Nor*Cal, CA
    I have a 92 2wd pickup. I just picked up a 4wd motor. Can I leave the 4wd oilpan on the motor? without any problems in the pickup?
    Thanks
  2. raylcc
    raylcc Addict
    Denver, CO
    I don't believe it will clear, but thats just going on what I have read. No "real world" experience on it. Sorry I couldn't help more.
  3. _Keith_
    _Keith_ Newbie
    Nor*Cal, CA
    Clear as in clear what? Ive done alot of online research and reading. I see the 2wd wont work in a 4wd because of the casing. But very little info vise versa. I do not have the 2wd pan no more so this is why I am asking.
    I did take some halfass measurements and they put the pan in the opening so to me looks like it will fit. Guess I will find out tomorrow.
  4. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Hey Keith use the 2wd oil pan and the pick up screen.
  5. Malessohomegrown
    Malesso,Guam
    Not sure what you mean by the casing but it will work.
  6. _Keith_
    _Keith_ Newbie
    Nor*Cal, CA
    I dont have it which is why I am asking if the 4wd will work...
  7. Malessohomegrown
    Malesso,Guam
    oil pan
    Sorry Keith i missed that part but pretty sure the 4x oil pan will hit the cross member and centerlink. It's deeper than the 2x.
  8. raylcc
    raylcc Addict
    Denver, CO
    When you have the engine just about in the engine bay where it should be, just release the lift arm on the engine lift really fast a couple of times. The engine will drop down onto the cross member and form a custom-to-the-truck indention. Problem solved! :waytogo:
    Ok, seriously, I know that the clearance it off, but how far is it off and where exactly is the oil pickup in the pan? Could the pan he has be "gently massaged" with a brass hammer to create the clearance and thus save him having to buy another pan?
    Just a thought.
  9. _Keith_
    _Keith_ Newbie
    Nor*Cal, CA
    Well anyone have a oil pan and oil pickup they want to sell from a 2wd
  10. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Yes you can beat the front of the 4x pan up flat to clear the steering.
