22re intake ???s
Discussion in 'Engine/Drivetrain' started by low_toyota92, Apr 3, 2011.
  1. low_toyota92
    low_toyota92 Enthusiast
    Nashville, N.C.
    92 ex cab
    i bought an upper and lower intake for my 92, it came off an 86re... I noticed that where th throttle body bolts to th intake its angled down.... are these two intercangeable??
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Sure you can swap all the hardware from either style back and forth but the 86 probably has the early double bellcrank on the throttlebody. Once you swap that out it will work just fine on a later engine. The later straight intake plenum flows better so I'd use it no matter what.
  3. low_toyota92
    Nashville, N.C.
    92 ex cab
    aight thanks...
