22re installation
Discussion in 'Maintenance/Repair' started by OGtoy, Jul 30, 2008.
  1. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    well heres the deal my friend just picked up a 89 extra cab pickup and the engine is about to go. we have another 22re on the side to drop it in. he has no experience at all with engine swaps but i have done a couple in hondas
    does anyone have a write up on how to properly take out the old motor and drop the new one in? and somethings i should look out for when doing the swap.
    thanks.
  2. Guam_Guy
    Guam_Guy Enthusiast
    Copperas Cove, TX
    1994 Toy in the Project phase!
    Make sure you mark all the connections and pull that bad boy out! There is nothing hard about swapping in a 22re for a 22re. The motor should be a 22re on the 89 right. I would freshen up the other motor before putting it in there. No point in doing all that work just to have the timing chain bust on you. Buy a rebuild kit from the internet and rebuild that motor for another 200,000+ miles of reliable service.
    Shootz!
  3. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    actually i believe the motor came out of an old celica.. the timing chain was done at 100k and there is about 120k on the motor. i was also told the seals and gaskets were also cherry and in like new condition.
    so im guesing marking all the plugs from the harness and putting um back in the right place would be the hardest.
    and as for cleaning i think were gonna degrease and clean up the new 22re going in... thanks for your input!
  4. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    What about the clutch & rear main seal?? When I had the motor installed in my truck I replaced all that cause its alot easier with it out the truck!! Oh & change the fuel filter too...the one that on the side of the block! :)
  5. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    1991 Toyota HiLux 4x4 RN101
  6. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    dont know about the rear main seal but a brand new clutch and flywheel were also included with the motor...
    fuel filter will be changed... thanks for the tips...
