22RE Ebay computer chips
Discussion in 'Engine/Drivetrain' started by Toyo Trucker, Dec 18, 2009.
  1. Toyo Trucker
    Toyo Trucker Addict
  2. TikiTantrum
    TikiTantrum Newbie
    92 xcab 2wd
    Claims are a bit iffy. Checked the seller's ratings, whenever someone rates a negative the seller either claims they are a competitor trying to tarnish their good name or call the buyer a "LIAR!!!"
    Seems the seller is 15...or just a liar...or perhaps the buyer was trying to tarnish their good name.
    What ever the case they seem to be making a lot of money of this item. There were 365 ratings (in the last 12 months) and $25 per sell...hold on...just...$9125.
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    ratings seem a bit padded. but for the price, its worth a shot. id wanna know what parameters it fools though.
  4. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    if you think your going to get the claimed 50+ hp on a 22re with just a chip, better think again.................but buy one and let us know hahaha
  5. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    What I can say on this issue ,is that LC Engineering told me not to waste money on rechipping,as they saw no gangs on the dynos!:cool:
  6. IronNam
    chips dont do anything, seriously
  7. tenfourtyeight
    tenfourtyeight Member
    Vista, Ca
    94 single cab; 91 4wd extra cab; 74 Hilux
    It's not a chip, it's a resistor that you wire into the harness to make the computer see a lower reading from the coolant temp sensor, keeping it in cold start mode permanently, dumping more fuel in. Don't waste your money or time.
  8. JDSnake
    JDSnake Veteran
    Las Vegas
    79 longbed
    If that is all it does, then as other's posted, don't waste your time. To gain a little power you run a little leaner than the factory safe setting. If this just richens it up, you are just wasting fuel
  9. jctoy29
    jctoy29 Addict
    surprise,az
    alot of that ebay stuff is crap.
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Not coming out of cold start mode will destroy your cat & made it run bad!!:cool:
  11. IronNam
    ^ yup
    plus cold start sounds like **** on an open exhaust
  12. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    destroy your cat and MADE it run bad ?
    they saw no GANGS in the dyno ? good I hope gangs arent living there. haha just kidding man but two typos I had to bust your balls :evil:
    hmmm.. if its to good to be true.. its not true.. also chips give 10% gains tops ? if the engine comes with less then 100hp and can gain 50 thats a 50% gain... if you have to come on here and ask if its legit its not legit.. good luck dont waste your time or money
  13. project_DragTruck_v2.0
    project_DragTruck_v2.0 Veteran
    These chips Do work, just not in the way you all are thinking. Here's how they work: By spending the money on the chip, your wallet is a little lighter, as we all know lighter means faster. If you drive your truck with your wallet in your pocket, then your truck will be faster! :D
    Seriously,though. Junk. They do nothing good, they do stuff, just nothing worthwhile. You'd get better gains for cheaper by stripping your interior....
  14. Poorboy
    Poorboy Newbie
    Northern VA
    95 hilux 2wd 87 hilux 4wd 79 F-100 2wd
    you will get more power out of bolts anyway.... 22re airflow is constricted badly. I would do a supra afm swap. Or if looking for ecu. Megasquirt is good and a lot cheaper than Lcengineering systems.
