22r vs 22re
Discussion in 'Engine/Drivetrain' started by flacostaco, Jun 6, 2012.
  1. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    ok so heres my lil dilema i own 2 trucks and i feel my 87 22r has more power vs my 94 22re both trucks are pretty much bone stock my 87 with a new head original block and my 94 has a new head with a bored out block (0.50) and while driving them my 87 has a harder launch over my 94 any ideas??? or are all that way the carb'd when camparing to the fuel injected shrug:
    just want to know what you guys or experience with stock engines???
  2. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Hard to compare unless both trucks have the same transmissions, rearend gears and wheel diameter... Only then would it be a valid comparison of carb vs efi... :waytogo:
  3. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    The harder "launch" can possibly be due to different gear ratios. The '79-83 2WD had 3.73:1 gears and was probably changed over the years.
    Rick
  4. patrickgraven
    patrickgraven Veteran
    Corona CA
    93 2wd pickup "home depot" / 2004 Toyota Sequoia 4x4
    I looked at the pictures of your trucks in your 87 thread and you difference could be due to tire size. I dont know what the ratio is for the 87, but the 94 should have the same as my 93 (which is believe is 3.59 or something close). Also you look to be running ranger wheels, I got a set of those a few months back and the tires that were on there were close to an 1" taller than the stock 195/75/14's that came stock on our trucks. So with that being said that inch size difference does zap some power. When my truck was lifted and I went to the 31's it ran like a dog until I regeared it. I think if you put stock size tires on it you may notice a difference. But I have never driven a carbed truck so my .02 is based solely on my efi truck.
  5. flacostaco
    87 pickup
    thanx for your guys input well im having an issue with the blue 1 while driving it it seems to hesitate like if it were governed today while driving it i thought it was done but then it slowed down a bit then came back on again any ideas would carbon build up do thisss or affect it ???? i feel like the truck isnt putting out the power it should the 22re any help :confused:
  6. patrickgraven
    Corona CA
    Found this while looking up gear ratios, maybe it could be some help for you in figuring out the 94'
    http://www.brian894x4.com/Gearratiosanddiffs.html
    according to this I have 3.42's stock (but I should have counted the teeth while I had it apart)
  7. flacostaco
    87 pickup
    hmm thanx for the link:waytogo:
