22R Timing issue
Discussion in 'Engine/Drivetrain' started by travisfab, Jul 27, 2010.
  1. travisfab
    travisfab Member
    San Diego
    84 Pickup
    I am trying to time my little stock 87 work truck. It's your basic carb'd 22R.
    The setting I need to get to is 0 degrees with the distributor vacuum lines pulled.
    The distributor bottoms out at about 5 degrees, I cant bring it down any lower.
    I am just not a motor guy, I'm guessing there is something on the carb I need to adjust, I'm just not sure what?
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    take the distributor all the way out, and do it again, you might be off a tooth
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    winar
  4. travisfab
    travisfab Member
    San Diego
    84 Pickup
    I pulled and re-indexed the distributor about 10 times, it either runs or it doesn't, and when it does run the timing just will not come down.
    Truck runs like a champ, smog sucks!
