Srry its so long in advance.....I just had my 22r rebuilt from bottom to top, got it home finally got it to start an the distributor locked up an busted the cam gear. I took it had the head checked, got it back home installed the head, so I tried to start it but it want, the starter will only click. I went an bought a new starter only to have it do the same thing. I put a socket on the crank bolt an spun the engine ovr an its Really hard to spin. I tourqed the bolts to 58ft lbs. like he manual says. Any ideas?!?!?! Im Lost On This One Thanks
yea...... check and make sure your battery is up to power and then try it agaain. jump it from another car if necessary. also, since you had it apart, check and double check to make sure everything has been connected and plugged in to where it needs to go.
STOP! and re-check cam in relation to crank timing.... Something is definetly wrong if you can't turn it over by hand. Even with the spark plugs installed you should be able turn it...
ok il check the battery but it should be fine, I stole it from my other truck.....il re-check the timming 2moro, I think iv already double checked but il make sure Thanks For The Help
