22r dies
Discussion in 'Engine/Drivetrain' started by RUBY82, Jun 17, 2014.
  1. RUBY82
    RUBY82 Newbie
    north dakota A
    82 HILUX LONGBOX
    My 82 hilux starts and runs but doesnt idle. Fires back up. Drives down the road and spits and farts but does run. New plugs, new fuel filter, cleaned the carb with a whole can of cleaner. New air filter. Sounds like its has a nasty cam when its running.
    Any suggenstions as to keep it idling without a new carb change as thats where im leaning to.
  2. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Check the cylindrical metal part on the back passenger side of your carb... it has a red wire and a white wire. These wires run to the same plug as your electric chock wires...
    Cut a piece out of the red one and hook 12v to it and see if it will idle. If not, cut a piece out of the other one and connect it to ground...see if it will idle.
    If not, your anti-diesel solenoid and connections are fine.
  3. RUBY82
    RUBY82 Newbie
    north dakota A
    82 HILUX LONGBOX
    Ill check it tonight
