92 Toyota 22RE with 5 speed transmission Just recently pull the motor out of my Toyota pick up to do a motor swap. The 22 RE has around 180,000 miles on it the timing chain was done 20,000 miles ago head gasket was done 5000 miles ago. Transmission shifts smoothly. We installed the LC engineering adjustable timing chain pulley we did the timing chain. The motor also has the full LC engineering pulley set up and a Chevy one wire alternator. The only bad that the clutch is starting to slip on it, and could use a new one. i'm wanting $1300 OBO!!!! for the motor and trans. Call or text me at (805)-813-0900
fwiw this sounds like a good deal even though it's high miles. did you do the valve seals when the head was off. was the head resurfaced clutch is an easy job with it OUT of the vehicle heh
