20r engine blow by? or?
Discussion in 'Engine/Drivetrain' started by beanbagz1, Aug 6, 2014.
  1. beanbagz1
    beanbagz1 Newbie
    Vancouver, Washington
    1978 Toyota Truck
    My 78 longbed has unknown miles on it... Though a piece of paperwork from the last owner shows 164xxx on a worksheet from 2001. That is the only thing I could find on mileage.. though I have probably put 15-20000 on it in the last 2 1/2 years driving it daily .. thanks for still reading, the problem I am now having is blow by. I changed oil/filter/air filter a couple of months ago after I saw a small amount of smoke . I also made the decision to add about 1/4 of a bottle of "engine restore" because my buddy had it laying around and said he had great success with it on certain applicatiions. It did stop dripping oil on the driveway after that change, but I am now having bigger problems. Is the blowby because of the "restore" product? Is there anything I can try? Here is a picture of my air filter, and oil pool beneath it. Please help me save this old engine! I love this truck and drive it every day.
  2. beanbagz1
    beanbagz1 Newbie
    1978 Toyota Truck
    pics
  3. beanbagz1
    beanbagz1 Newbie
    1978 Toyota Truck
    56 of you look but no replies? Am I on a Chevy forum or something? Lol
  4. beanbagz1
    beanbagz1 Newbie
    1978 Toyota Truck
    56 looks but no replies?? Is this actually a Chevy forum???what in the world
  5. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Did you check/replace the PCV valve?
  6. Litneon
    Cocoa, FL
    94 xtra cab
    You say that there is a bit of smoke? When? On startup? All the time?
    Then you show a pic of the oil in the filter housing.... That's normal because of the nature of the recirculation system and crank case evacuation. Now, too much there probably isn't normal, but on a high mileage engine, there will be some blow by.
    The additive likely did little to nothing to affect any of the changes you've seen, especially since you only added 1/4 of a bottle. You can check to make sure the PCV is operating correctly, but you'll likely find that it is. A compression test will be more telling in this circumstance.
  7. night_amuse
    night_amuse Member
    Edmonton, Alberta
    81 4x4 4spd
    check the PCV valve and do a compression test as said
  8. beanbagz1
    beanbagz1 Newbie
    1978 Toyota Truck
    Im really pretty new to working on cars.. so farthe 20r has been a good engine to tinker with. Changed oil, replaced air and fuel filters. No more smoke ;) where is the pcv valve?
