2" lowering block Q?
Discussion in 'Suspension/Chassis' started by AJIZZLE510, Apr 23, 2010.
  1. AJIZZLE510
    AJIZZLE510 Newbie
    ihave 15" rims 205 60 tires and i was wondering if they would rub with a motorcycle loaded in the bed weighs around 400lbs (Stuntbike) Im going to flip b/j and crank torsion bars as well or should i just get the 1" blocks??
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Measure from the ground to the top of the wheel well with nothing in the bed.
    Load up your stunt bike, and measure again. This will tell you how much the springs sag. When loaded, measure to see what will hit first above the axle or tires. Deduct 2" from that to see if it will clear.
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    what he said ^^
  4. standardbyker88
    lynnwood, wa
    but i had a 92 lowered 3" in the rear, and could stuff a ducati in the back without rubbing. suspension wise wont be the issue. its just if the tires will clear.
  5. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    Depends on the offset of the wheel also.
