2 air tank 2 compressor setup
Discussion in 'Suspension/Chassis' started by krazedprof, Aug 21, 2009.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    do i need to run 2 pressure switches or ??? i have never done a dual setup right now all i have is a 3 gallon tank on my truck and im putting a 5 gal with it so i will have 8 gallon can someone help me out please 3 gallons of air is just not enough
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    well, if you have both tanks T'd together, and both pumps relay off the same pressure switch, you shouldnt need 2.
    unless you are running a large pump and a little pump, with the little one set to come on at say 145 (175psi max system for example) to cover little usages, and the bigger one to come on at say 110 for when you start getting switch happy. does that make sence?
    but if you have the same pump twice, id give each one its own relay, and have that relay triggered by the same pressure switch.
  3. krazedprof
    krazedprof Addict
    iowa
    ok thanks they are both the same size compressor(air zenith) and yeah im just t'ing them together and i do have 2 relays
  4. standardbyker88
    lynnwood, wa
    sounds like that should work fine then. i dont see why youd need another switch taking up a port.
  5. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    You only need one pressure switch...follow standardbyker88 advice & youll be good!
  6. standardbyker88
    lynnwood, wa
    if you wanna get really tricky, have another tiny tank like a 1-1/2 gallon, with a check valve leading to it. so it isnt used except when its needed. then on the feed to the valves, have it come from both the main system and the extra system, with a manual ball valve on the small tank. so if you have any issues with the main system, you have enough air to get off the ground.
  7. krazedprof
    krazedprof Addict
    iowa
    thanks guys seem to work except now it is either drawing to much power or my alternator is going cause my truck died while running with the compressors going does that sound like it too you?
  8. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    double check all your grounds & wires to make sure that you dont have any loose conections. also check the battery itself...when I installed the air suspension on my eclipse & soon truck I upgraded to a larger battery. it also wouldnt hurt to check the alternator too just to make sure that its putting out enough amps! those compressors do draw a lot of power!!
