(2) 20R heads and (1) intake
Discussion in 'Parts and Accessories' started by standardbyker88, Aug 13, 2009.
  1. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    i have 2 20R intake manifolds. just stock condition. one is still installed so i know its not warped, the other i have not checked or cleaned up. both are pretty dirty. but in good shape. i have a picture of one. i do not know if they are both electric fuel pump heads, but the one in my truck is. not sure if it has the bosses you need for p/s/ect. i can look though. also have a stock 78 egr style intake.
    hows 25 for a head and 15 for an intake sound? ill ship if desired. or local. im near seattle...ish.
  2. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Dibs on one of them heads! Pics please??
  3. 77yoter
    77yoter Veteran
    seattle
    77 sr5 shortbed, 81 shortbed, 90 4x4
    are you serious 25 bucks you are pretty much just givin them away are they stock heads cause i would be interested in one if there has been no machining done i would like to build a head for my lux
  4. standardbyker88
    lynnwood, wa
    yeah. for real. 25 bucks. i only paid like 20 at the yard for the one in the garage, and the in my truck was in my truck. im trying to clean out my parts pile a bit. no work done to either of them that i know of.
  5. 77yoter
    77yoter Veteran
    seattle
    huh thats sweet right now im not to sure if i want to rip the motor out of my celica and put in my truck or just build the one thats already in there
  6. standardbyker88
    lynnwood, wa
    well i have one on the floor, and the other will be out by the end of the weekend.
  7. standardbyker88
    lynnwood, wa
    heres the head with the cover on
    heres the underside of the cover, you can see the inside of the head a bit. i kinda wanna keep this cover, it has different baffling than the one i have on now. but when i put the new head on this weekend, that may change when i look at it again. mine doesnt have a baffle under the front breather which is very odd.
  8. standardbyker88
    lynnwood, wa
    i dont have the cam for one, the one in the truck im not saving though. i probably have the cam caps for the garage head though.
  9. 77yoter
    77yoter Veteran
    seattle
    alright cool deal not worried about the cam i am planning on going with a rv cam all im looking to do is a mild port and polish unlike the one in my celica its a full stage 2 head ill let you know in the next day or two if i want it
  10. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    Dibs on the second head only if it has the p/s and a/c bosses. Ton your too fast prim!
  11. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    Early bird gets the worm prim... I got 2 hrs head start if anything is posted on the east coast! Lol! :evil:
  12. standardbyker88
    lynnwood, wa
    yeah, BYE gets first dibs, then 77yoter
  13. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
  14. standardbyker88
    lynnwood, wa
    bottom side of the garage head. the one from the truck is in pretty good shape too. i havent flipped it over yet though. i still had a little bit of crosshatching at 107k. but i beat the hell out of it, and with the valve guides in the head it had i was usually a little low on oil. lol.
  15. standardbyker88
    lynnwood, wa
    yes, that is a big ass speaker. i know. :D :ROFL:
  16. 77yoter
    77yoter Veteran
    seattle
    from what i can tell that bottom of that looks good
  17. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    Yup, for some reason the 20R heads have a better casting then the 22r's... I pulled a head from a 78 Corona and it didn't even start to corrode... I've seen a '86 runner, '93 pickup, that had to get some welding work done to fill in the corrosion... :shrug:
  18. 77yoter
    77yoter Veteran
    seattle
    ya i hate the 22r i have always had problems with them never a problem with the 20r though
  19. standardbyker88
    lynnwood, wa
    its pretty clean. exhaust valves had a bit of caked on stuff but seems like whatever truck i pulled that from wasnt beat too hard. i started scrapping it and gave up, was gonna hot tank it.
  20. 77yoter
    77yoter Veteran
    seattle
    sweet deal all i plan on doing to it is just a mild port and polish
