1994 Instrument Dash Cluster
Discussion in 'Parts and Accessories' started by Roland Deschain, Sep 30, 2021.
  1. Roland Deschain
    Roland Deschain Enthusiast
    02B717A0-3507-46E1-A677-CDDC740B933B.jpeg Does not fit US built trucks from what I understand. My truck has a separate dash bezel which this cluster does not use. I’m reselling it for what I paid. $135 shipped 210F9FE7-44E9-4A91-B33E-11B0732649AD.jpeg 9926EA76-9F5F-42BB-A9E5-F42DB6967524.jpeg
  2. Roland Deschain
    594504B1-9868-4E8B-A005-A0AEFB72925B.jpeg Well I bought another cluster bezel off eBay. It does appear to fit properly but I assume it came from a truck with an automatic transmission although that doesn’t seem to make sense. The reason I’m thinking that is there is no cutout for the clutch bypass switch otherwise it’s the same as the broken one I removed. E0CEE72E-FD99-4AF1-98FD-B3590E742B35.jpeg
  3. Roland Deschain
  4. Roland Deschain
    And finally installed in the truck, the bulb in the 4 way flasher/hazard light switch is burnt out. I had two other bulbs in a switch I removed from the first replacement dash and neither of them worked either. F84D219A-3C4F-42E6-88C1-3F3F7434E400.jpeg
  5. Roland Deschain
  6. Roland Deschain
  7. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    That came out great! what did you spray it with?
  8. Roland Deschain
    That I sprayed with SEMS matte black trim paint. I used the Duplicolor Grease/Wax remover then shot it with Duplicolor Adhesion promoter then the trim black.
  9. Justin Danger
    Bay Area Peninsula
    dang, that is doing it the right way for sure.
