Hi guys, Another noobie question from me... I had a weber carb installed last fall and the truck has been running well all summer, until last night when I took it out. I stalled at the first stop sign; didn't think too much of it, but then it continued to stall when slowing down and eventually just had to head home. Carb seems to idle ok, but I noticed fuel is only squirting into one side of the carb bowl, not normal, correct? And easy way to clean this out? I admit I don't know much about these carbs, would it be worth having my local shop tune it up? View attachment 23309 Thanks for any info/help!
Looks like you have a Weber. You may need to check if the float is sticking low and not letting the bowl fill up. -check your filters, may be clogged. -is the choke staying closed after its been running a for a couple minutes(assuming you have an electric choke)
Thanks for the suggestions. WHat filters may be clogged? Also, fuel is supposed to shoot into both sides of carb correct? THanks!
Theres a primary and a secondary. Secondary opens much later than the primary(probably past half throttle) for mo' powah.
