1970 hilux no headlights
Discussion in 'Interior/Electronics' started by Brennan, Feb 10, 2019.
  1. Brennan
    Brennan Newbie
    Santa Cruz California
    70 Hilux rn12
    i have no headlights and my headlight switch turns on all my marker lights but not headlights. \\\
    will provide more info if i get a response to the thread .
    thank you all!
  2. jetas
    Are the fuses good? Are the sealed beams good? Are the connectors at the headlights all corroded?
  3. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Could also be the switch itself
  4. fred heath
    fred heath Addict
    Raleigh, NC
    Not sure if they used thermo links that early. A melted one would keep your headlights from working.
  5. justaguy
    justaguy Member
    75 hilux, 84 xtra cab, 86 1 ton, 87 xtra cab 4x4
    I had (rather still have) this problem on my truck. There is a relay switch above the passenger inner fender under the hood, and it's most likely burnt up.
    I have had no luck on finding a new replacement, and I currently don't drive it enough to care that much.
    But when I do need to turn on the lights I just jump the wires on the connector with a wire.
  6. jetas
    You can always just wire in a regular relay
