Hi all I am new owner of a 94 Toyota Pickup 2WD Regular cab and still learning the truck. All stock right now. I am strongly considering a set of Pro Comp 51 size 15x10 -44 on 205/50/15 tires Before placing the order, i just want to make sure that (1) the wheel will clear the brake calipers, (2) it will clear the other suspension parts, and (3) will the wheel + tire rub on the inner fender well? if a -44 offset will hit the caliper and other suspension parts. should i choose a -39 offset instead? I am currently on stock height right now but will research what lowering suspension to get. maybe belltech lowering kit Thanks in advance. Here's the info on the wheel: Pro Comp Steel Wheels | Part Number: PCW51-5165 Wheel Width:10 Inches Style:Rock Crawler Series 51 Finish:Black Construction:Steel Wheel Diameter:15 Inches Offset:-44 Backspacing:3.75 Fitment:Universal Fit Brand: Pro Comp Steel Wheels Bolt Pattern:5 on 4.5 Series:51 Series District Series - Finish:51 Series - Gloss black
Find scrapelux on instagram. Hes running i believe that exact wheel spec on a 84-88 which is the same and the 89-95 chassis.
