Discussion in 'Maintenance/Repair' started by dagnisaun, May 14, 2012.
  1. dagnisaun
    dagnisaun Enthusiast
  2. patrickgraven
    patrickgraven Veteran
    Corona CA
    93 2wd pickup "home depot" / 2004 Toyota Sequoia 4x4
    those studs are threaded on. when you buy a new water pump they come with new ones. If you decided to repalce the water pump they are cheap, I think my new one was about 25$. But if its good you are i no way sol. Just figure a way to get it out and you can replace the studs.
  3. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Yeah Patrickgraven's right they are studs.Try to drill it out without buggering the threads.
  4. Malessohomegrown
    Malesso,Guam
  5. gilpet79
    gilpet79 Enthusiast
    MD
    94 2wd
    i dont see why 3 studs would be a problem
    But if you just drill/ knock out the stud you can just run a nut and bolt and be fine, Its not like they balance the pulley off the water pump.
