1 ton torsion bar swap
Discussion in 'Suspension/Chassis' started by shin, Nov 7, 2010.
  1. shin
    shin Member
    cheese,wi
    91 base
    there is a mid 80's toyota camper dually at the junkyard... and i was wondering if those torsion will bolt right into a 89-95 truck... also anyone if the front sway bar is bigger on those or not... thanks
  2. joeyota653
    joeyota653 Enthusiast
    it should go on since theyre both 2wd..
    im looking into a swaybar swap too bt my donors a 4x.
    how much additional stiffness do you get from camper and 4x swaybars???
  3. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    Shin the 1 tons should fit right in, if by chance they dont all you need is the sockets that they slide into so if you are getting them from a junkyard it wouldn't hurt to get them aswell.
  4. joeyota653
    hey evol would you happen to know if the 4x bars would fit?
  5. Evolmotorsports
    SCV cali
    1987 RN50 Hilux
    No they wont.
  6. 89yotadually
    89yotadually Newbie
    charleston, sc
    1989 regular cab dually
    i have an 89 dually, as far as i kno sway bars are interchangeable as mine bolt in stock location
