1 ton sway bar and torsion swap
Discussion in 'Suspension/Chassis' started by Kristian43, Feb 14, 2011.
  1. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Ok so does anybody know:
    1.whats the diameter of the 1 ton sway bar and torsions?
    2.Can they replace stock parts on an 89 non 1 ton?(with little to no modification)
    3.does anybody have any pics of em?
    4.does anyone have either of these that they would like to sell me???
    Gracias! :cool:
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    if i remember correctly, the 1 ton sway bar up front is a 28mm? if not 25mm....... i dont remember. i know the weak ones are 23mm. in order to run the 1 ton bar i would imagine you need the bushings and C brackets that hold the bar to the frame. thats about it. i believe the outter links are the same. torsions i believe are the same. most of the suspension change was in the rear leafs. i believe some 1 ton pickups also ran a rear sway bar in the dually trucks.
  3. thundering02
    thundering02 Addict
    Fenton 63026
    SD pretty well nailed it. I'd hafta measure to find the size... the endlinks are identical and the c brackets might be just with different rubber inside.
    Leaves definitely base is 3 leaves I have 5 or 6. Torsions are going to be next to identical as all the weight is intended out back.
  4. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Does anybody on here have access to a 1 ton that could take the measurements?? :shrug:
  5. IronNam
    basically when you go grab the 1-ton parts, just take everything from it :D
  6. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Yup im planning on it. Imma take all the measurements on my suspension stuff and take lots of pics before I head over to picknpull next week im really hopin they have a 1 ton there
  7. SD YOTA
    essential upgrades you will likely want from the one ton are the front sway bar, and the rear if it happens to have the optional rear sway bar attached. torsions are the same. i looked it up today at work. standard 23mm bars.
    the rear leafs will allow you to carry more weight but would likely disintegrate your lower back bone when you hit the first bump on the road without any weight in the back........ :shrug:
  8. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Sd yota- thanks bro :waytogo:
    ok well im not gonna get the rear springs from it cuz I already have an extra leaf on it and it rides pretty stiff as it is. Imma che k on that rear sway bar when I go though. And I guess im just gettin the sway bar! Thanks peeps :applause:
  9. SD YOTA
  10. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    I guess the next question would be anybody have a 1 ton sway bar they feel like selling to me??
  11. goingnowherefast
    goingnowherefast Enthusiast
    Haddam CT
    1965 Stout
    I personaly found the front sway to be 15/16-1 inch on the 1 ton, just buy new rubers.You can use the same steel brackets. And the torsions(87 1tons instaled in a 93) were a mm larger in dia. Don't have a way to measure metric outside dia. right now. The front brakes (discs and calipers /non duelly) will also fit and are larger.
  12. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Thanks for the info on the brakes! :waytogo:
  13. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    So I tried lookin for some 28mm sway bar bushings to fit the 1 ton sway bar and I couldn't find any. Are you guys pretty sure its a 28mm? The largest I found was 25mm bushings.
  14. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    the 1 ton sway bars are 25mm and i have one for sale
  15. TheLoLux
    Simi Valley, CA
    i just put one on my truck last week
