1 ton rear leaf springs on a 1/2 ton
Discussion in 'Suspension/Chassis' started by wtsane, Mar 18, 2014.
  1. wtsane
    wtsane Member
    Panhandle Florida
    1980 SR-5 4x2
    Does anyone know if the 1 ton springs used on campers fit the mounts on a 2wd/SB? I am looking to do light towing, and am considering the swap. I know where the leaf springs can be had, so that is not an issue.
  2. da9guy
    da9guy Member
    arizona
    1978 short bed hilux
    i have 1 ton springs on the rear of my 78. i didnt put them on but it doesnt look like anybody did any fabrication to mount them. on my little short bed it is an extremely rough ride unless i have some serious weight in the bed tho. if you are going to be riding around empty most of the time i would consider air bags or helper springs or some other alternative
  3. wtsane
    wtsane Member
    Panhandle Florida
    1980 SR-5 4x2
    Fair point, I may go that route.
  4. da9guy
    da9guy Member
    arizona
    if you dont mind me asking, what are you going to be pulling with that little guy that you feel you may need to beef up the suspension?
  5. eighty_D
    eighty_D Member
    Fairbanks, AK
    '79 SR5 2wd lwb
    Brakes are the main issue towing/hauling. Those solid front disks and tiny rear drums fade fast when you're hauling or towing a heavy load. Use a lot of engine braking in the hills
  6. wtsane
    wtsane Member
    Panhandle Florida
    1980 SR-5 4x2
    Brakes are on my list, but hills are not an issue. I live at the very top of the second highest peak in Florida, a lofty 38 feet above sea level.
  7. eighty_D
    eighty_D Member
    Fairbanks, AK
    '79 SR5 2wd lwb
    Should bolt up as far as I know all 2wd springs are the same width and the same length eye to eye the 1 tons just have more leaves. Maybe a more knowledgeable member will weigh in on this.
  8. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
    i use simple air adjustable shocks in the rear for heavy loads. air them up to level the load, take air out when done. no harsh ride either.
