transmission or clutch?
Discussion in 'Engine/Drivetrain' started by 88pickup, Dec 13, 2010.
  1. 88pickup
    88pickup Member
    10,000 Lakes
    1988 Longbed
    While in 30-40 mph truck just slow down.
    If you hit on the gas the engine will just rev.
    Pull over and engine is running fine even though truck can't move. Start fine also without using clutch pedal.
    You can put it in gear and left go off clutch pedal and engine won't go off.
    I thought it was the transmission went out but friend say need new clutch.
    Any suggestions?
    -88 pickup with 22re 5spd
  2. IronNam
    Clutch.
  3. 88pickup
    88pickup Member
    10,000 Lakes
    1988 Longbed
    Oh sweet. I hope so LOL
    thanks
  4. dillinja666
    ya if you cant stall when holding the brake and letting out the clutch then your clutch is wasted. I hope you didnt go into the rivits on the clutch material.
  5. thundering02
    thundering02 Addict
    Fenton 63026
    clutch and no rivets vote too.
  6. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    sounds like clutch to me also, if your rev your engine and the ratio is not transferred to the tranny/wheels, then your clutch is slipping horribly. Count on maybe having your flywheel resurfaced as well or going light weight while its out, may as well change rear main seal also when you buy a new clutch kit.
  7. 88pickup
    88pickup Member
    10,000 Lakes
    1988 Longbed
    Rivets?
    Will do. thanks
  8. thundering02
    thundering02 Addict
    Fenton 63026
    Rivets .. what holds the materials together. much like the brake pads (flywheel resurfacing vs turning rotors...)
  9. 88pickup
    88pickup Member
    10,000 Lakes
    1988 Longbed
    Aw, got it.
    thank you sir.
