130w headlight bulbs
Discussion in 'Interior/Electronics' started by Chip Morton, Nov 9, 2010.
  1. Chip Morton
    Chip Morton Member
    San Diego, CA
    Hey gang,
    I saw some 90/130w H4 headlight bulbs and it got me thinking . . .
    Can I just pop those babies in and be good to go? Or would I need to do some heavier wiring or something?
    Thanks!
  2. Litneon
    I'm guessing you should be good. Even at 130 watts with a low voltage of 12, you are still only around 11 amps of current. #16 wire can handle that easily and I believe the wiring to the headlights is at least #14 which is typically good for 15 amps.
    You may run into a fuse size issue though....
  3. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    where did you see these? a link?
    i was running 90/100w h4 in my taco...with no issues.
  4. Chip Morton
    Chip Morton Member
    San Diego, CA
  5. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    What color are the lights going to be
  6. Chip Morton
    Chip Morton Member
    San Diego, CA
    I've read a couple different things. One guy said both hi and lo beams were white. Another guy said his hi beams were white but the lo beams were very yellow-ish. I'll let you know!
  7. Dgerfan55
    lake elsinore CA
    94 pickup
    cool take some pics to if you can
  8. Chip Morton
    Chip Morton Member
    San Diego, CA
    Will do!!
