My Intro '75 LongBox and Some Questions
Discussion in 'Pre-1975 Build-Up/Project Threads' started by drama808, Oct 22, 2010.
  1. drama808
    drama808 Member
    North Dakota
    84 xtra cab, 75 Long Bed, 09 Ruckus
    What's up guys, my name's Brandon. Last night I drove 450 miles round trip after I got out of class for the afternoon. I went to pick up a '75 Longbox that appeared to be in pretty good shape from the one picture I saw and what the guy told me. I'll get on to the pics, and then a couple of questions.
    I started it, took it for a short cruise...everything seemed legit. I made it about 30 miles and started smelling a oil. Stopped to check it out and my air cleaner was leaking oil. Neat! I've search and read to check/replace the pcv valve. The problem is, I can't get a new grommet for it anywhere. Is it possible to just get a newer 20r valve cover and then run that year pcv valve and grommet? Or what is my best solution?
    Damn, I hope that's what it is and I don't need to tear this thing down already.
    Also, here are a couple pics of my '82 Datto KingCab. I bought it at the beginning of the summer and have driven it a total of about 100 miles since. I threw a weber on it then it developed a knock. Put in a newer motor (92k), clutch, windshield, brakes, wheel cylinders and then lowered it on blocks and cranked torsions. Oh, and painted it.
  2. minidreaming
    minidreaming Enthusiast
    North Carolina
    83 Long Bed Deluxe
    Those are some sweet trucks!! I really like the 75 and what good condition.
    On the side? Do you live in Grand Forks? That really looks like Grand Forks, ND to me. I used to live there two years ago...welcome to TM by the way!
  3. drama808
    drama808 Member
    North Dakota
    This is indeed Grand Forks man. Good eye!
  4. minidreaming
    North Carolina
    83 Long Bed Deluxe
    Where did you find that sweet ride...and if you dont mind me asking...how much that puppy cost ya?
    I used to live in the apts by the UND golf course...
  5. drama808
    drama808 Member
    North Dakota
    Ah, I paid a fair price I believe...
    Any ideas on my valve cover issue? Why is the 75-76 different?
  6. minidreaming
    North Carolina
    83 Long Bed Deluxe
    Well congrats...
    regarding the valve cover issue, i am not real familiar with the 20r, but i believe a 20r is a 20r, you should be able to replace with a different year. Someone feel free to correct me if i am wrong
  7. IronNam
    Welcome to Toyota Minis! Nice truck man!
  8. Nook
    Nook Addict
    oregon
    The early 20R valve cover used the larger metal oil cap with a lower profile boss where it screws in, the later cover had a taller boss with a smaller plastic screw in cap. The grommet should be the same for both covers, don't know if you can get one seperate at the parts store, they come in engine overhaul gasket sets, possibly even in a valve grind set too, or the dealer should be able to hook you up.
    Any of the 20/22R valve covers will bolt on, but if you use a later 22R square nose cover with the dual chain used in the 20R you will need to trim the oil baffle under the oil cap or it will rub on the timing chain.
  9. drama808
    drama808 Member
    North Dakota
    Nice! Thanks for the info man. I called the dealer and the parts stores today and got the same info from everyone....they can all get the pcv valve but can't get the grommet for the '75 for some reason... they could get them both for 77-newer though.
  10. andysmiley17
    andysmiley17 Veteran
    Louisville, Ky
    82 Diesel
    those are 2 awesome trucks u got there! so what are ur plans for the yota
  11. drama808
    drama808 Member
    North Dakota
    Well, hopefully figure out what the deal is with it blowing oil all over the place first. I also need to figure out why I has no heater fan. I haven't even looked at any of the fuses or anything yet. After that, not too sure. I've recently worked out a deal for an 84 xtra cab as well, but it sounds like that is getting traded for a custom frame with rx-7 irs. So, that could end up under this. The same dude I'm trading the 84 to dropped me a line on a 69-72 that I've been looking for for awhile now. If I pick that up, this will just get static dropped and driven.
  12. The Crowing
    The Crowing Enthusiast
    Colorado
    1976 Toyota Pickup
    I usualy save all the stuff. Do me a favor and post a pic of exactly what your looking for and ill root around in my garage.
  13. dillinja666
    ya ill look in mine too...got a 20r rotting in mine that might have that seal.
  14. drama808
    drama808 Member
    North Dakota
    I appreciate the help guys. I got the pcv valve and grommet replaced today. No help. So, judging by what I've read, that means I need to either a. rebuild or b. replace...
    So, my next question is this. I have an '84 22r with 5 speed that I could put in it. Is this a direct swap? Pull it out of the 84 and drop it into the 75? Would I need to swap driveshafts or anything like that? Even with the internet at my disposal, I just cannot find much tech information on the swap.
  15. The Crowing
    Colorado
    1976 Toyota Pickup
    Wait I think I know to what you refer and im 100% I have 2.
  16. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    maybe just mess with the tranny mount and that's about it, other then that, the engine is a BOLT ON!
  17. blue77
    blue77 Member
    Port Townsend Wa
    77 hilux?
    Nice trucks dude.. Haha im on NA "rallytalon93".. took me awhile to put the two threads together:duh:
  18. drama808
    drama808 Member
    North Dakota
    I'm blownef9 on na. I remember when you posted your truck up man. Small world.
  19. drama808
    drama808 Member
    North Dakota
    Well, I'm putting my Datsun up for sale. Gonna have to start dumping some funds into the Toyota. And my wifey already hates me. Living in an apartment just isn't going to work with 3 pickups, her car and my ruckus.
    I'm going to start my 22r swap this weekend. If I just pull the one from the '84, it'll bolt right up, won't have to change anything out. Correct? Is the wiring any different?
  20. DROPT
    DROPT Addict
    Whales Vagina
    ahhh grand forks. i had a fun weekend there man. i got so freaking wasted at sledsters. omg you ever go to that bar?
