How To Do A Ball Joint Flip (by SD Yota)
Discussion in 'Suspension/Chassis' started by SD YOTA, Mar 22, 2010.
  1. SD YOTA
    ive been running the flip for 5 years now...... no breakage *knock on wood*
    and yes, ive hit pot holes and really mashed on this truck and tossed it around corners and everywhere else.........hard!!! :waytogo:
    every other truck i have done a standard 3/3 or 4/3 drop has needed no alighnment when done (although i always checked it). the only real time you will need an alighnment is when you do spindles since the spindles mount and move everything and change steering angles a bit....
  2. dwnshfter
    dwnshfter Member
    Well, looks like I'm getting an alignment then ;)
  3. dwnshfter
    dwnshfter Member
    Well?
  4. switchhappy
    switchhappy Member
    Clermont, FL
    94 single cab
    would there be any issues if I were to do this on my bagged 94'? just got it bagged last week and the upper ball joint pretty much binds up when it's layed out. If I can get an 1 1/2" drop with no issues that would be freakin awesome. Would I have to to upper & lower though since the upper is the one that binding or would it be the same doing just lower?
  5. burnzya
    it will help even on a bagged truck. i've never spaced one for 1.5" though.
    you could also pie cut the upper arm and that will really help with the binding. i've found that changing the location of the balljoint after it's been bagged can reduce the lift a little bit.
  6. stihlalive00
    stihlalive00 Member
    clarence
    93 pickup
    awesome writeup, im gonna try this one for sure. i bought my truck with blocks in back n looks like just shocks n torsion mod, i get bad bump steer. any options to lesson the harsh ride n keep it low?(only have about a inch of tavel up front. p.s. awesome yota in the driveway with supra celica wheels :waytogo:
  7. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    So i just read what you said about the fender lines being lower in the back.... i ran out side o look at my truck lol. Your right! They are lower in the rear!!! I never noticed that before
  8. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Ya me ethier, till u said something. Thanks for the write up and heads up about our trucks.
  9. IronNam
    you're one of the only few people who actually recognizes that the bj flip will retain some more torsion rate. :waytogo:
    my frame is currently level with the ground.
    i need to go even lower... truck still looks high to me, even though the exhaust is getting closer to the ground... and i'm already tucking most of the sidewall in the rear. :evil:
  10. 78yoda
    78yoda Member
    Knoxville, TN
    78 hilux, 4 speed...blaha
    can ya do tha bj flip on a 78....non-torsion bar???
  11. o.d.
    o.d. Newbie
    did mine today and had a slight noticeable drop about an inch or so,i also did not use spacers didnt have enough time , also the handling got better just a tad. is there anything else i can do to lower it without loosening the torsions and no drop spindle?
  12. Wizz
    Wizz Member
    I might be the only one but I had to grind smooth the underside of my balljoint because it was not flush , it's was like 1/8'' to high in the middle ... maybe I have aftermarket balljoint , not the stock one..
    Once everything was grinded smooth , it's was good! :D
  13. SD YOTA
    not much else to do without either dropping it with the torsions, replacing the spindles or, lower control arms.
    yea...... some of the ball joints i found had a small rise or "bump" towards the center portion of the ball joint. this was never an issue since i usually used a minimal of one washer on each bolt to space the ball joints from the arms. i usually use anywhere between a 1/8th inch tick to 1/2 thick washer to space out the ball joint for that extra bit of drop. :waytogo:
  14. SkeeloG88
    SkeeloG88 Enthusiast
    Tennessee
    88 reg cab
    Did mine today. Sorry no pics yet. But wanted to mention if the strut rod/support doesn't come close to lining up on the bottom of control arm to loosen em up and slide bolts in and bam it's done.
  15. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    I just used a BMFSD (Big MoFo ScrewDriver) in one of the holes to align the other one and put the bolt in it.
  16. SkeeloG88
    Tennessee
    88 reg cab
    Had my dad prying on it and I was gonna slide bolts in still couldn't get it so we put the socket to it ha but I used washers and got a noticeable drop I'm pleased but now Im slanted down. Couldn't put the blocks on yet due to sh!TTY weather but I'm off Friday so pics r coming
  17. IronNam
    holy **** dudes, are you using two set of jacks to help you with your install? one under arm, one under frame. moving it around helps aligning that stuff.
    my .02
  18. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    Yes. I have done many. It doesn't take a huge amount of force to align it....but the BMFSD helps.
  19. Barret S
    Barret S Veteran
    Ellisville, MS
    86 Standard cab 2wd
    flipped my lowers, noticed a little gain, but not much, flipped my uppers, then i saw some good results.
  20. SkeeloG88
    Tennessee
    88 reg cab
    How hard was it to flip the uppers?
