Need 76 20R dizzy and drive gear
Discussion in 'Engine/Drivetrain' started by AToyRuck, Aug 29, 2010.
  1. AToyRuck
    AToyRuck Newbie
    Driving back from PDX this weekend the distributor seized and sheared the drive gear too. Anyone in the Seattle area have a useable vernier adjustable (stock 1976) distributor and drive gear for sale?
    Hope all is well.
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I have a drive gear from a 22r if that helps, and a dizzy but Idk if it will work for you.. its for a carb motor tho
  3. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    I have a spare distributor and drive gear on my 78 parts truck... There is also a 75 parts truck in the Arlington Pull-a-Part that is mostly complete (as of 08/28/10)... If you are interested, shoot me an offer. I work in the Northgate area and live up by Everett.
  4. AToyRuck
    AToyRuck Newbie
    V8 T,
    Not sure if 22R is useable, but I bet it would be if it uses points and condenser. Where are you located?
  5. AToyRuck
    AToyRuck Newbie
    Curtis,
    I've emailed you privately to exchange contact info.
  6. AToyRuck
    AToyRuck Newbie
    Menz,
    Result. Possible that low oil may have overheated the distributor, or just that it had 109,004 miles in it. Don't know. Back on the road though. Hope oil filters actually filter oil.
    Note to self: Install magnetic drain plug next oil change.
    Thanks to all who offered, or helped.
