Something Stupid.
Discussion in 'Engine/Drivetrain' started by jrealmuto1, Aug 28, 2010.
  1. jrealmuto1
    jrealmuto1 Member
    MS
    1986 Yota 2wd
    This is what i got. A rebuilt motor for $400. Sat up for 2 yrs out side... put it in my truck and got everything going.. there is this ticking,chain sound, from the front. Took valve cover off when i put my new on and what i find is the timing chain guide not installed on the left time. So theres lots of slack in the chain for about 2 minutes after cranking. i was told by 3 mechanics that it wont hurt it, to run a WIX oil filter with anti drain back. Anyways my question is, WILL this hurt it? It rattles for about two minutes until oil pressure builds up. Lmk somethin. :shrug:
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Ive been ripped off 4 bills on a "rebuilt" 350 im my camaro. Started it up and it had a #8 rod knock like a mother......
    But as far as yours. 2 min to build oil pressure? Either the pump, sump, or the bottom end is wore out.
    The chain guide..If you crank it without a guide on, the chain can slip. These are slammer motors so you run the risk of bending the valves. But most likely the single chain streched and destroyed the guide. And the noise is the chain rubbing the timing cover. Are you getting coolant in the oil?
  3. jrealmuto1
    jrealmuto1 Member
    MS
    1986 Yota 2wd
    i take back the oil pressure...put it this way..i can crank the truck, itll rattle, i give it a little bit of gas after two minutes the rattle goes away. and im 100% sure its the timing chain. I can pick the slack up. :eek:
  4. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    no good. take the cover off and replace the whole timing kit. since the guide is not there, it is wearing into the chain tensioner and is is rubber so its going to eat through it. and im pretty sure when it gets to the metal inside, it will grenade your motor
  5. Raffaelli
    Houston
    82 Longbed 2WD
    Pull the timing cover, and get a chain set from somewhere.
    (not cloyes! its crap!)
    Rock brand is awesome. Thoroughly impressed. Get it from Engnbldr.
    You might need a timing cover too. Id bet on it.
  6. jrealmuto1
    jrealmuto1 Member
    MS
    1986 Yota 2wd
    good deal men, i will do. i had a feeling it wasnt good for it hit the side walls. thanks for it all! :waytogo:
  7. dillinja666
    also the 3 people who told you that it was ok for the chain to not have guides.... go kick em in the nuts..
  8. jrealmuto1
    jrealmuto1 Member
    MS
    1986 Yota 2wd
    lol i ought to, i guess its the rednecks here in mississippi who consider theirselves auto techs.
