Side draft throttle cable linkage
Discussion in 'Engine/Drivetrain' started by Pdubya, Aug 25, 2010.
  1. Pdubya
    Pdubya Newbie
    Hey I'm switching from EFI to Mikuni 44's. I bought the carbs of a guy who ran them on a 20r in a late 70 celica, so I'm not sure if I have all the **** to connect the cable.
    Any one got any good pics of how they've done it?
  2. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    I have a stock cable pulley welded to the throttle shaft on mine. Don't have any pictures of it though, sorry. You will also need to make some sort of bracket to hold the cable in place.
  3. six7one_KDR
    six7one_KDR Veteran
    From Thee Island of GUAM,Live's in WASHINGTON / NO
    1976,1979,and also YES a 1973 HILUX
    Dual carb's/sidedrafts
    a lil set up on my 79
    set up on my 86
  4. Pdubya
    Pdubya Newbie
    On the 86 is that the stock cable you used?
  5. six7one_KDR
    six7one_KDR Veteran
    Cable
    Yes,its a stock cable but it has an adapter from the stock cable to the ball on the linkage.but there's a way to just run it straight up from the stock cable to the linkage.let me get sum pick's from that set up.when i find them ill post them up.
  6. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    please do that i need pics. thanks
  7. six7one_KDR
    six7one_KDR Veteran
    cable set up
    here's a pick of the stock cable set up with the dual carb's:
    LOL...on the zipp Tye's,this set up had all the proper bolt's on it but the owner never likes to listen so one night at the race track his truck started to have a throttle problem,come to find out he was missing one bolt on the throttle linkage.so he ends up pulling a qwik fixx with the zipp tye's.i tell him thats only a temporary fix."guess wat, that was like 4 month's a go and he's still rockin them zipp tye's"
  8. yotarip
    yotarip Veteran
    You will have to do some fabricating to make it work but it's not hard to do. Just make sure that the throttle motion is smooth and free from binding. I have a set of mikuni's that didn't come with complete linkage. They had the ball sockets on the levers but no rods. I found that the throttle rods from the early volvo 740's worked perfectly. I also used some throttle linkage parts from the 280z's to complete the mikuni linkages.
