upgrade for better gas mileage toyota truck 85 ?
Discussion in 'Engine/Drivetrain' started by oldpunko, Aug 18, 2010.
  1. oldpunko
    oldpunko Newbie
    any suggestion ? thinkin maybe change rear end for freeway driving and swap from 4 speed to 5 speed or swap smaller carb for better gas mileage ?? e mail me at [email protected] thanks
  2. dillinja666
    1 post and you want us to email you...sounds like a phisher...no spank you
  3. Jake Breyck
    Jake Breyck Member
    Tampa Fl
    1uz powered 86 pickup
    this is a forum, why would we email you our responses, is this your first forum?
  4. IronNam
    easy there guys, seems like a legitimate request for suggestions on what he can do to improve his truck's mileage.
    anyway, anything to help the engine breath better, the more efficient it shall run.
    swapping the rear end ring and pinions for something lower to decrease engine RPM's will help. the 5spd will provide a more flexible selection of gear ratios as you drive around.
  5. dOBER
    dOBER Member
    Rear end swap 3.07 Final Drive (forgot trans code)
    5 speed swap (what I'd like but not within tight budget)
    aerodynamics (lower car, front valence, tonneau cover, undercarriage planks)
    engine - make sure it's in tip top shape, maybe advance timing and play with diff octane.
    I'd go for skinny reinforced tires that allow 44psi+
    and a nice tail wind pushing you into the 30 mpg zone
    play w driving techniques like drafting big truck and hypermiling - it works
