difference??
Discussion in 'Engine/Drivetrain' started by yotabeast12, Aug 9, 2008.
  1. yotabeast12
    yotabeast12 Newbie
    wuts the difference between a 22re short block and long block??
  2. Nook
    Nook Addict
    oregon
    In the old days the term short block meant you got the block with the crank, and pistons installed, the long block had the same plus the cam, timing components, timing cover, oil pump, oil pickup, and pan installed.
  3. yotabeast12
    yotabeast12 Newbie
    so theres no size difference
  4. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    guess not ?
  5. yotabeast12
    yotabeast12 Newbie
  6. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
  7. Nook
    Nook Addict
    oregon
    The term short block and long block like I mentioned earlier reffered to the old days of engines like Chevy V8'S, in the case of the Toyota I suspect a short block would still be just the block, crank, pistons assembled and ready to swap all your other parts onto, and the long block apparently is assembled with the head, timing components ect. and ready to swap the outside parts onto.
    I think the difference your reffering to from the LC site is the difference in the short (lazer) deck block compared to the tall (early pre 84) deck block itself depending on the model year of the engine.
  8. V8_TITAN
    Tampa Fl
    89 std cab
    why spend 6k on a new 22r ? how about you spend 2k on a 7mgte ?
  9. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    OR just put a V8:D :D :D
  10. yotabeast12
    yotabeast12 Newbie
    i was thinkin bout that jus spending 3500 and dropping a 350 in it
  11. trap
    trap Addict
    orange county ca
    92 pickup
    depends on your personal preference. I would personally feel stupid taking out a incredibly reliable gas efficient motor that will run atleast 200k if maintained to put in a gas guzzling american no where near as reliable v8. A toyota v8 on the other hand would be a bad ass swap, it would get much better gas mileage then a american motor and would look much more at home under the hood.
  12. lownloud
    lownloud Toyotaholic
    Plains, Montana
    MY preference, being a loyal Toyota fan, I would never put a Chevy,Ford, Dodge whatever anything in my truck, but thats just me, power or free, wouldnt happen. I prefer the reliablity and toughness or the Yota motors. . .
  13. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
