I'm selling my 22rte turbo engine and turbo setup. It's a Jasper Engines remanufactured 22rte with about 10k on it. I've installed ARP head studs and Cometic MLS headgasket. I have a aftermarket turbo manifold and all the turbo parts for a swap into a 85-88 toyota truck. I was putting it into a 89 and up truck so I was going to use the stock 22re ECU and bigger 235cc Mazda Miata injectors. I also have everything to swap into a 89 and up truck. You will have to make your own intercooler pipes. I'm going to list all that I have. I would like $1800 for everything. You can email me at [email protected] or call me at (931)446-4274 ask for Brian. I'm located in Mt. Pleasant, TN. I have some more pics up on Monday of everything. 22rte Engine ARP Headstuds, and Cometic MLS Headgasket T-3 Turbo Manifold T-3 Turbo with internal wastegate Oil Supply and Return lines 2.5" Downpipe with 3" V-Band flange Injectors Stock 22rte 295cc rebuilt and flowed. Upper and Lower Intake Intake Boots Throttle Body 22RTE ECU 22RTE AFM Brake Booster Heat shield All water pipes for heater core and radiator.
