Torsion bars
Discussion in 'Suspension/Chassis' started by planemos, Aug 7, 2008.
  1. planemos
    planemos Toyotaholic
    British Columbia
    I want to perform the torsion bar drop. How far can I go down (how many turns) and what is the best way to do this... jack it up?
  2. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Jack the front of the truck up & get the weight off the tires. Make sure to place jack stands under it for safety!! Ok...look at the end of the bar where the bolt is & youll see two nuts on top. Remove the top nut so youll be able to loosen the lower nut...the top nut is there to lock the lower one in place. After you get the top nut off take a closed end wrench & place it on the top nut & it will wedge itself in place when you start to turn the bolt at the bottom. Its really hard to say how many turns youll do cause its all up to you on how low you want to go. Just try to keep count of the one side you do so youll be close when you do the other side! If you get stuck or have anymore questions then feel free to ask!
  3. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    smctoy said it all! but there is one thing to keep in mind you might want to do before you lower it! get some whiteout or a bright color paint marker to mark the orginal location and then go on. just a thought you might want to consider just incase you want to bring it back to stock.
  4. planemos
    British Columbia
    Low!
    How low is a pickup with t bars removed?
  5. Litneon
    Ooh, yeah, don't go there. Rides like crap.
  6. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    yess it doessss... lol but its REAL LOW
  7. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    DONT TAKE IT OUT!!!!!!!!!!!!!!:) you will regret it.
  8. V8_TITAN
    Tampa Fl
    89 std cab
    like me :)
  9. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    and ME too:D :D :D
  10. V8_TITAN
    Tampa Fl
    89 std cab
    haha you still have them out ? ive had them out for 9 months i think now and hopefully lownloud sends me his soon
  11. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    no i put them back in. i dont throw nothing away till im dead sure what im running is going to stay.:p
  12. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    81 long-bed goodness
    About how many turns are an inch?
    Ive heard 4 turns are about an inch...that seem right?
  13. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    If I can remember correctly, that does sound about right.
  14. Steve@CanDO
    Steve@CanDO Member
    NOR-CAL
    94 Toyota Standard cab
    Its been a while but for some reason I was thinking it was about 1 full turn = about an 1/8th inch but like I said I havent done anything but bag em the past several years.
  15. planemos
    British Columbia
    Actually lol it's funny you are telling me this. What I really need is a set of arms to complement my Belltech drop spindles. I guess that means I will need bags too. But for the rear I have a Firestone Freightliner bag. I am getting obsessed with this truck sitting in my Dad's garage. But I think he wants it out of there soon.
