header question
Discussion in 'Engine/Drivetrain' started by 75hilux, Aug 14, 2010.
  1. 75hilux
    75hilux Member
    Sacramento
    75 hilux
    hey guys i got a 75 toyota hilux and i wanna buy a header for it but i don know where to get one that will adapt my egr pipe onto it... what can i do... do i need it connected or can i jus buy any old header not hook up that part of the egr help me out thanks
  2. Jake Breyck
    Jake Breyck Member
    Tampa Fl
    1uz powered 86 pickup
    well unless you live in the republic of California where its a mandatory life sentience if you ever remove any emissions device from your car, you would be better off deleting the egr. I take the egr off all my cars just to have less crap on it. but i live in florida, no one cares.
  3. dillinja666
    Is your 75 pre smog or post smog? Its right on the border there
  4. 75hilux
    75hilux Member
    Sacramento
    75 hilux
    the truck is pre smog so i don need to worry bout that but i have the stock carburator on the truck and it needs the egr to function correctly.... i jus want to see if there is a trick to havin the egr system with an aftermarket header
  5. standardbyker88
    Yep. That trick is a weber carb swap :D
    I have a pacesetter. It was cheap, and has held up to almost 2 years of high revs and smacking road turtles
