SupraTruck goes under the plasma cutter again!
Discussion in 'Suspension/Chassis' started by Sound.Vision.Soul, Aug 8, 2010.
  1. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    So i figured it was time to fix my messy steering issue. With some good help from some info i found on here i cut and modified my steering center link.
    Pics to follow shorly. Soon as the upload.
  2. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Okie there done! Enjoy.
  3. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    good job looks nice. so hows it feel now?
  4. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    way tighter. i had ridiculous bump steer before.
  5. Dgerfan55
    lake elsinore CA
    94 pickup
    well thats good to hear. So whats next on the list?
  6. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Alignment, exhaust, oil change lol
  7. burnzya
    nice! glad to see you back on the forum!
  8. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    yea work has been keeping me super busy working ungodly hours. When i came on there were over 2000 new unread posts lol.
  9. shin
    shin Member
    cheese,wi
    91 base
    is toyota brake clean more superior then other brake clean.... lol
  10. IronNam
    so why did the cutting and rewelding made it better?
  11. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Cleaned the oil off real good! Lol
    Buddy of mine works at a Toyota Dealer.
    And the reason it made it better was because when i first put the 7M in it i bent the pitman and idler to clear the oil pan. Bad idea. It caused all kinds of bump steer and wander at higher speeds. this way with it notched its back to its factory steering angles.
  12. IronNam
    OH! okay!
    I get it now.
    Hmm, should've just cut and weld the oil pan itself :D
  13. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    believe me! I was gonna go that way, but this was a thousand times easier.
  14. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    I still need to get a good steering stabilizer. Ive been running without one since day 1.
  15. IronNam
    No steering stabilizer + 400+hp
    You must have steady hands mister. :D
  16. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    yeah theres a trick, quick hands lol. the smaller gt steering wheel helps a bunch. I had to remove mine when I installed the engine as it was hitting the oil pan. I just need to get under there and extend the bracket out to clear and ill be good.
  17. IronNam
    i think we just need to find some rack and pinion system to retro fit in our trucks.
  18. TOY808801
    TOY808801 Newbie
    I totally agree with that. Other than throwing a couple grand in for a custom rack we really dont have an easy option for that Issue..
    When I swapped out the stock spindles for a MK3 supra's I had the meanest bump, and lean steer... Luckily by just flipping the tie rod ends from the top of the steering arm to the bottom, and raking the caster back I was able to just about cure the problem.
    If a rack were available setting up the proper geometry would have been a bit easier with what ever location would be best to mount the rack.
  19. burnzya
  20. IronNam
    ay yi yi.... i was thinking about grabbing a rack from a junker! lol
