starts and dies only after the 3rd time starting will it run,have checked all the grounds replaces the fuel filter fuel pump fuel reg. maf coil plugs and wires cap m rotor,,after it stays running runs very well.
sry been so long,,,,needing some help on how to check the fuel pressure if I hook a gauge after the regulator i'm getting 62psi,,,there is no smoke coming out
is it after it sits for a little bit? if so, you gotta draw fuel to the motor, it's probably bleeding back away from the motor.
sorry it's been a while but i have found the problem with my Yota the timing chain guide on the left broke and jump one tooth on the timing, parts ordered should be adding to the 392K miles by the wkend.
