after engine warms up will not idle
Discussion in 'Engine/Drivetrain' started by rink45, Jul 4, 2010.
  1. rink45
    rink45 Enthusiast
    vancouver, wa
    78 shortbed
    have a 78 pickup stock 20r. it will start up when cold and idle good for about 15
    minutes then start to sputter and die. i can restart but have to give gas to keep
    it running. carb was just rebuilt and it does misfire a little. Any ideas would be great
  2. rink45
    rink45 Enthusiast
    vancouver, wa
    78 shortbed
    anything?
  3. 400DollarPhil
    400DollarPhil Enthusiast
    Washougal, WA (east of Vancouver)
    78 SR5 longbed
    same exact truck. same exact problem.
    i diagnosed mine to be a combination of a vacuum leak and a bad EGR vacume check valve.
    haha im located in washougal. if you have any questions feel free to shoot me a text
    360 936 4829
  4. rink45
    rink45 Enthusiast
    vancouver, wa
    78 shortbed
    sorry for the delay phil. I'll text ya soon with some questions. thanks!
  5. 400DollarPhil
    78 SR5 longbed
    no problem man. feel free to hit me up whenever. im in Vancouver all the time, i work right off 14, near I5
  6. rink45
    rink45 Enthusiast
    vancouver, wa
    78 shortbed
    ok...... still having idle problems.....
    changed water temp switch
    checked compression 160 across
    vacuum is 20lbs steady
    fuel pressure 4lbs steady
    the motor ran good with emission components still installed but after i removed the smog pump
    and unhooked egr it warms up then dies(unless i close the choke)
    does the carb need to be adjusted for not having the emission stuff?
    junk the stock carb and buy a weber?
    any help is very appreciated!!!!!
  7. dillinja666
    well...if it was mine, i would junk the carb and get the weber.. i love mine. IF you wanna keep the stocker try to richen up the mixture a lil, if its running with the choke on it sounds like its super lean..
  8. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    I'd go for a Weber too, although I'd try turning the idle screw out a little and seeing what happens. Might just be lean. If you just rebuilt it it might need some adjustment. Those stock carbs are touchy to vacuum signal too, if you've got any of those hoses wrong it won't run right. That's why I went for a Weber, one hose, done. I'd make sure it's the carb that's the issue first and eliminate any other issues (vacuum leak, timing, etc) before you spend the $$$.
  9. rink45
    rink45 Enthusiast
    vancouver, wa
    78 shortbed
    thx for all the help
  10. ranger6
    ranger6 Member
    Marysville, Wa
    86 22RTE
    I had more problems with those Aisen carbs. I finally had enough and went to pull a part and found a Weber. It was like night and day. No tinkering or tweaking and no big ugly ass air cleaner.
