help with my 79 sr5
Discussion in 'Engine/Drivetrain' started by dailydriven, Jun 16, 2010.
  1. dailydriven
    dailydriven Enthusiast
    Fall City Washington
    79 std cab
    so my truck fires up and i can run it and drive it just fine but i will not idle period... doesnt even try so wtf is going on anyone else have this problem????
  2. standardbyker88
    Check for vacuum leaks on all the lines, as well as intake to head and carb to intake mounting surfaces. Or it might be the idle mixture screw or idle speed screw worked itself out of adjustment. Also make sure the wire is going to the idle speed cutoff solenoid still.
  3. dailydriven
    79 std cab
    where is that solenoid located i couldnt seem to find it earlier
