3"Blocks - MiddleLeafSprings = :D
Discussion in 'Suspension/Chassis' started by IronNam, May 31, 2010.
  1. IronNam
    I did it under an hour and tried to take a video of me doing it, and then shortening it so its a time lapse, but the camera only took 17 minutes at a time.
    Tread is tucked but sidewall's about to rub haha
    Will get pics soon!
    How dare u post a suspension mod and not put up pictorials??
    Such a child...:lol:
  3. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    I second that. You know better.
  4. SD YOTA
    werent you dropped on blocks before??
    how much lower did you go from where you were at?
  5. IronNam
    I've initally did the leaf spring removal...
    then I got a set of ubolts and 3" drop blocks... put the middle leaf back on.
    and about a year or whenever later, pulled my leafs.
    I'm not sure how much i even dropped.. I'm thinking 2-3" estimate.
    "before"
    "after"
  6. IronNam
    To go box WAS two fingers off the ground.. before.
    To go box WAS on it's side off the the ground... after.
    To go box is torn up but still attached... currently
  7. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Looks like you need to drop the front a little to even it out. Looks good, tho! :waytogo: Thinkin bout doin that myself, or getting drop leafs.
  8. IronNam
    all the pickup/4runner fenders up front have a 1" larger opening... or was it 2"???
    The look bothers me, but i'm sure the front is slightly higher.
    Thanks Dave! I say you should get drop leafs to retain the ride.
  9. standardbyker88
    Follow the main body line down the side, the rear arch is shorter. So it looks lower. But i still vote to drop the front more :D
  10. Dgerfan55
    lake elsinore CA
    94 pickup
    how many leafs did you pull? But looks nice. what tire size is that?
  11. standardbyker88
    :ROFL: He is running 205/75/14s...and is seemingly proud of it. I think they look retarded. But he won't listen to me :ROFL:
  12. sleepingciv
    sleepingciv Enthusiast
    damn thats with 3 inch blocks? and one leaf removed? cant wait to see what my 4inch blocks look like with the bed on lol
  13. IronNam
    pulled one leaf.
    I'll stick with my tires til they're bald... and hopefully not get stuck in a rainstorm.
    my initial problem was the fender tabs chewing my sidewall
    Truck's frame is relatively level with the ground as you can see.
    With my friends sitting in the back, it'll bottom out and squish me mudflaps.
  14. sleepingciv
    got any bigger pics lol
  15. NotAvailable
    NotAvailable Addict
    i like that ek ferio
  16. sleepingciv
    ferio 4 door not 2 :)
  17. IronNam
    I can try harder! maybe the pics will get even BIGGER!!!
    Thanks, that's my sister's bf ( or my friend)'s car. If he was a ricer, he would've been kicked out of my house 2.5 years ago.
  18. standardbyker88
    Seriously...down size them pics kid :lol:
    And its time to break a wooden bat, and roll the handle end through the wheel well, and work your way to the other end. And flex the bedsides out, then rebolt the bracket in on the outer hole. And ya know, replace the tires before they get eaten. :ROFL:
  19. IronNam
    I already removed the fender lining, took this metal tube that's about 1.75-2" (somewhere in between) and rolled the fender. This time with the fender and **** removed so the bed doesnt get dinged inside out.
    I also removed one bracket...from each side
  20. jetas
    looks good kid
    Id pull my leafs again but im scared of my pinion bearing going "PGH" again..
