Newbie
Discussion in 'Introduce Yourself' started by yotamom72, May 22, 2010.
  1. yotamom72
    yotamom72 Newbie
    Tuolumne, California
    1972 Hilux shortbed
    Hi all,
    I'm new to all this. I have a 1972 Hilux and am having a hard time getting parts.
    I'm slowly restoring my old little workhorse. Just finished the brake system rebuild, but I can't find gaskets from the brake cylinder to the booster, and booster to the fire wall. Does any one know where I can find the material to make them?
    Pennie
  2. smartmonkey
    smartmonkey Veteran
    Australia
    v320, 620, 720KC, RN46, LN46, YN65 & B2200
    Welcome to the site from the aussie bloke
  3. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Welcome to TM! Just a warning....we are a bunch of pic junkies here on TM. :eyecrazy:
  4. priusjames
    priusjames Enthusiast
    Laguna Hills, California
    75 Hi-lux
    Welcome to the site.
    Not sure about the gaskets, will keep my eyes open.
    Share some pics!
    James
  5. 400DollarPhil
    400DollarPhil Enthusiast
    Washougal, WA (east of Vancouver)
    78 SR5 longbed
    welcome from Washington!
  6. dillinja666
    when you replace the master, it should come with a new gasget to the booster. Booster to the firewall..you might just have to make some out of that generic gasget material. its pretty easy just trace and cut.
  7. yotamom72
    yotamom72 Newbie
    1972 Hilux shortbed
    My little Buddy
    Thanks for the welcome! I put some pics in the gallery, but they're not very good. Can you find it in the snow? I got it out of a field where it sat without an engine for years. It was given to me for helping a friend move his auto shop. First I had to get the black widows out, then I stuffed a 20R in it. Off it went after a couple of adjustments and some air in the tires. I didn't know what to expect. I had to use a bicycle brake cable for my throttle cable because everything is on the other side. I need an 18R for it. That was in 1998, and its still going strong. It's a mean little bugger in the snow too! It used to be a Mason Shoe delivery truck and I remember it running around when I first moved here in 1979. Who would have thought I'd be driving it now. Sure would like to find that owner.
  8. HOOLIGAN620
    HOOLIGAN620 Member
    Alta Loma
    1985 Toyota 4x4, 1986 4Runner
    Check out Rockauto.com
    Ive been finding alot of stuff through them..
    And Welcum!!
  9. priusjames
    75 Hi-lux
    Rock Auto does rock...and stuff arrives pretty quickly.
    I found a local place (Hub auto Supply) that's been around for YEARS that actually had the rotors, calipers, and some other stuff in stock...I got the idea from somebody who suggested Napa (they didn't have much in stock, but could order stuff...probably from Rock Auto...heh).
    Check around your area for a local parts supply place that's been around a long time (rather than a chain store)...
    As far as making gaskets, easy to do...I used to be able to buy packs of several sheets of varying materials/thicknesses of material, bet those are still around (minus the asbestos ones, of course!).
    Good Luck!
    James
