plug and play for your /84 MTM any REASONABLE offers considered for this rare working "kit" sign. switch cable cable bracket & bolts clutch switch computer part # 88240-35020 main dash switch actuator and vac line + bolts part # 88200-35030 removed from a /84 2WD Toyota complete "plug in" kit .. I have included some part #'s so you can confirm this will fit your truck .. and you indeed have the plugs for the system .
Hello, i have an '84 2wd, standard cab, 22r w/ auto trans and overdrive. do u think i could put the cruise control components u have for sale on my truck. its my daily driver and i would like the cruise control for my commute to work and what not. i dont know how to check parts numbers to see if they are compatible, if u let me know how to check that then please let me know and i will do so myself. also what are u looking to get for the parts if they are compatible with my truck, would i need any other parts, wires or anything else to have it functional? sorry sop many questions, i am a newb to TM, and am looking to upgrade my daily driver any way i can thats reasonable. thanks you for your time and have a good day. -Punter93
yes .. this kit will work with an auto tranny as well .. wiring should be there .. is your truck an SR5 ?
