Hey TM'ers! I've been running into a problem with all the wheel/tire shops around here. Everyone is telling me they either don't have 18's to fit my truck or can't get anything with a lip. So what would like to know is what size wheel (including width) you're running and the offset. Please help me out!
Im not running rims right now but my last set was 19x8 +42 offset They rubbed the strut rod tho. try some 18x8 with like a +30-ish offset. Maybe even something in the +20s would look good.
Thanks for the info guys! Toyota530, do you know the offset of your wheels. EFnetOper, I like your wheels. Diamo 25 Karat right? I do have 2/3 drop and don't plan on bagging it.
Yep, that is correct sir. I have 2" belltech drop spindles and bj flip....haven't touched the torsions yet. I need to cut some away before I do.
8.5 and a high offset will definitely rub the strut rod. As i said, low offsets will fill the wheel wells nicely
Whats your offset? ANd are u sure they dnt rub? I never noticed mine til i turned the wheel all the way and trying goin n i heard a nice lil kkkgggggggggggghhhhhhhhhhh
My offset is +40 but I have a very long turning radius since I installed the spindles....I haven't adjusted the steering stops on my spindles yet but I gurantee you they have never rubbed...I remove and polish the insides and outsides of my rims all the time and would freak if there was any wear.
haha. yea i flipped out when the paint was chipped off my 19s from the rubbage. Spindles probably do make the difference
I am looking at some right now, 17X7.5 with a +38 offset. i thinking that should work pretty good. going to run 205/40s. Sound about right???
225/40 has more meat, less stretch than a 205 on a 7.5" Idk y im so scared to fck up one one my wheels on a pothole.
