Lowering block question
Discussion in 'Suspension/Chassis' started by jj53913, May 16, 2010.
  1. jj53913
    jj53913 Member
    Ontario, Oregon
    Where are you guys buying your lowering blocks? I have Schucks/O Rilley's, NAPA, and autozone around here and all of them carry blocks but the have the small guide pins and my yota has big guide pins.
  2. IndianScout
    IndianScout Enthusiast
    1986 Yoda Truck
    I got mine here, work great
    link..
    no problems at all, fast shipping and a nice set..
  3. jetas
    Got mine at pepboys. They fit right on. I may need to shim the top pin later on to fit snug in the axle. But i aint worrying too much right now. Cant drive it anyway... lol
  4. jj53913
    jj53913 Member
    Ontario, Oregon
    Man I hope I can locate some within a 60 mile radius tomarrow so I can get it done sooner, I did my BJ flip last night and went to install the drop blocks and a no fit so now im rollin all "ass-in-the-air".
    Now I wish we had a pep boys here.
  5. IndianScout
    1986 Yoda Truck
    I feel ya, I live in ND we don't have anything up here, nice thing about these blocks is they fit my 86 toyota with no mods,
    good luck in your search..
  6. IronNam
    I bought my $30 3" lowering blocks and bolts from Autozone.
    Place the lowering blocks between the centering blocks and leafs.
  7. jetas
    pretty much whatever blocks you find at Autozone/Kragen/Pepboys, they all sell the same blocks
  8. mnasholm
    mnasholm Enthusiast
    Eugene, OR
    1991 Std Cab 22RE
    I drilled out the hole bigger and then made a spacer to make the pin bigger, fits perfect. There are pics in my project thread
  9. burnzya
    I buy mine from www.airbagit.com
    But they are local so buy from the warehouse. I got 5" angled blocks with new u bolts for $36.
  10. thundering02
    thundering02 Addict
    Fenton 63026
    Beefed taco is a sponsor here.
  11. goingnowherefast
    goingnowherefast Enthusiast
    Haddam CT
    1965 Stout
    Beware of the cast blocks,steel or alloy.They will break or atleast wear down from the spring pearch then wobal out the pin.Check out beefs stuff it looks good and soild.
  12. 94Yota_05CBR1K
    94Yota_05CBR1K Veteran
    San Diego aka SD, Daygo. Cali
    94 YoTa Mini 2wd
    Haha... yours was "ass in the air" but mine was "ass on the ground.":D I was "stargazing" for a day because I didn't have access to a impact gun to do a torsion drop so mine was opposite of yours. I actually did the torsions today. I will do a new post with pics if anyones interested to look. Oh btw I got some alluminum blocks from Pep Boys. I got a homie that has the same kind and he's had them for about 2 yrs and haven't cracked or anything. I tried to get a hold of beefed for his steel blocks since he lives close but he never responded. The ones at Auto Zone should be fine.
  13. jetas
    Whats goin on with beefed? He hasnt really been around here for a few days.
  14. dwnshfter
    dwnshfter Member
    I threw my 3's on tonight, but I think I have some axle wrap or something.... ****s not right. It was to dark to try and figure it out tonight but I THINK that I didn't line up the upper pin on the block with the axle. Is that something that could cause an issue?
  15. IronNam
    most likely. evenly torqueing down the nuts on the bolts helps too.
  16. dwnshfter
    dwnshfter Member
    Oh, I removed the helper spring too, I think the bolt that holds them all together might be too long also and could be hitting the base plate that everything bolts to, Imma go to the parts store and get a shorter bolt to replace it with too..... see if that helps ;)
