How low can i get w/o cutting wheel well?
Discussion in 'Suspension/Chassis' started by 86extTURBO, May 13, 2010.
  1. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    I have an 86, i had the sr5 rims on it and i did a 2 inch drop on it with blocks and the torsion bars, but i put 17 steelies on it and they lifted it back up. I was wondering if there was a more efficent way to lower it with out rubbing or cutting it.
  2. smartmonkey
    smartmonkey Veteran
    Australia
    v320, 620, 720KC, RN46, LN46, YN65 & B2200
  3. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    go with a 3-inch drop block in the rear & do the balljoint flip in the front.
  4. yota4life
    Pull the middle leaf aswell
  5. standardbyker88
    if youve seen my 78, the rear suspension is the same. i have a 4-1/2 block, and pulled all leafs except the main and smallest. i got almost a 7" drop.
  6. SD YOTA
    your rubbing or lack there of will depend on what size tire you also choose to roll with. im not sure if you have seen mine but my truck sits at a 8/7 drop.... i run a 205/50/16 size wheel and tire both front and back and rub minimally......
    you should be fairly safe from most rubbing up untill you pass the 4/4 drop mark........ at least in the front anyways. the rear fender wells are fairly deep and wont have hardly any issue clearing anything back there.
  7. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    Right now im running 215/ 65 r17 and the front is rubbing, but im goin to get 215/ 45s soon. and i need to pull the inner plastice from the wheel well, then i shoul be able to lower it another inch. What would be the best way to keep travel, and get lower? Drop spindle or replace the lower arms?
  8. planemos
    planemos Toyotaholic
    British Columbia
    Drop spindle if you want airbags eventually. Lower arms could be better than spindles in the strengthening of the front suspension. Since it is all old stuff.
  9. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    i think ill go with the arms. Anyone know a good place to get them i need some twos or threes?
  10. jetas
    yea that tire size is killing your drop...
    3" drop LCAs are what your mainly guna find.
    2" drop spindles.
    BJ flip
    drop blocks
    drop leafs
    pull middle leaf
    And my least favorite method, Mono-leaf....
    About the rubbing, Either take a BFH to the inner fenders, or cut..
  11. SD YOTA
    if you go with the control arms, invest in a set of energy suspension bushings for the front end...... guaranteed they are all pretty chewed up and rotting..... this will tighten up the suspension a good noticabele amount.
    tire size is hurting you and untill you change it yer gonna run into issues. 205/50 be a nicer ride quality tire size. you can go fairly low without much ribbing on that size. the thing that will make a big difference when dropped is also a good gas shock such as bilstein shocks.
  12. standardbyker88
    do all of that. :D
