And here.... we... go.
Discussion in '1989-1995 Build-Up/Project Threads' started by Litneon, Mar 26, 2010.
  1. Litneon
    Yep, the body drop will do it...
  2. HNG-10W
    HNG-10W Newbie
    Syd, AUS
    91 xcab
    loving this truck mate, the wheel and paint combo really set it off
  3. yota4life
    Hey can you get some pics of when you mount everythingunder the hood like power steering an all that stuff. Thnx . An the truck looks amazing
  4. SD YOTA
    awesome man! very nicely done!
  5. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    can you get a parts list of everything you bought ???, I want to bag the rear off my truck but Im so afraid of screwing the link setup up.
  6. NotAvailable
    NotAvailable Addict
    thats the rubbing...fck..
  7. yota4life
    That rubbing is because your bodied. Check out streetsource I know they have threads about what other people did for tht.
  8. NotAvailable
    NotAvailable Addict
    yeah i know but idk if tubulars would help? i try street source but theres so much threads i give up.
  9. Litneon
    It would buy you some room, but at what cost? $700? I think you'd be better off (if this is the only problem,) clearancing the A-arm. Cut out what you need to clear, and take a piece of 1" or 1 1/4" tubing and weld it back in to close it up. There is plenty of meat on the factory arm. So it would end up looking like a cute little C notch for the steering linkage.
    And I will post up more pics as we finish the details.
  10. planemos
    planemos Toyotaholic
    British Columbia
    Yea I've seen some arms rusted right through and the truck is still driving around daily.
  11. yota4life
    Lol at the cute little c notch for the a arms haha that was funny. But ya my buddy has a bodied 86 an it is cut out for clearance. I'd try that before buyin the cando arms. But it's ultimately up to you
  12. NotAvailable
    NotAvailable Addict
    yeah i plan on cutting it jus wasnt sure wat route to go..and yes there are about 800 bucks...frick..thanks for the opinions and help.
  13. Litneon
    Sure, I noticed that you will need to clearance the bushing and washer slightly too. Shouldn't be a big deal at all...
    I've got my stock arms if you mess it up...:rolleyes:
    Doubt you could though.
  14. yota4life
    Ya he'll have his stock arms an I'll have mine off in a week or so for my cando arms. The cando arms cost me all together 850. Ridiculous but I'm sure they're worth it
  15. TSLUX
    TSLUX Member
    WAIPAHU
    90 xtra cab
    with the rear tires being 9.5" were you running it that wide without cutting your bed or did you have to cut the bed to run that?
    and size on front?
  16. Litneon
    265/35/18's in the rear with 9.5" wheels, and 225/40/18's in the fronts with 7.5" wheels.
    The rears fit with the 3" static drop no problems, and could've dropped it more. Only cut out the bed for the bags... You'd have to be sure of the proper offset though, I believe these are a -20mm. Usually (I'm told) toyota pickups and tacos run a -42mm offset.
    In the front, I wasn't happy with the -42mm either and ended up adding a 25mm spacer plus the 1/4" hat rotor for the brakes, effectively creating a -10 or -12mm offset. They're out there, but I like the wells filled.
  17. burnzya
    man it looks awesome!
  18. Litneon
    Thanks, wish I'd have done it much sooner. The ride is amazing....
  19. Litneon
    Her name is Penny.
  20. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    it rides better?
